I’m finally diving into UltraFX, specifically the new Saturation FX. Unfortunately I’m a bit lost on the different modes and what each of them specifically do. Are they presets to do specific things? Any help would be greatly appreciated. Thanks everyone!
You can find more info on page 141 of the dLive Firmware Reference Guide. From that page:
Mode selects the model, there are 5 available.
Mode A Triode Valve Preamp Model. Rich in second and third harmonics. This model is
the cleanest available on Saturator with low harmonic distortion and a gentle roll-off on
frequencies over 10kHz. (Least aggressive).
Mode B Pentode Valve Preamp Model. Rich in second, third and higher order
harmonics. Minimal high frequency roll off.
Mode C Late 1960s germanium transistor based Preamp Model. With characteristic roll
off on frequencies over 12kHz.
Mode D Channel strip model with vintage bipolar transistor and small signal transistor.
Wide high frequency lift at around 8kHz and for air and clarity.
Mode E Tape Drive Preamp model. Accurate low and low-mid attenuation with extremely
aggressive levels of distortion when Gain is turned up to maximum. (Most aggressive).
Thank you so much Jacob! This is most helpful.
My pleasure!
