I am having issues syncing the madi signal coming into the iDr-48 rack from my madi recorder. Every other channel sounds like garbage and I can’t get a clean healthy signal.
The current setup is iLive T112 connected over ace to iDr-48 then I have the madi card in slot B. The madi recorder is a sounddevice 970.
I have tried changing all the sync references from both idr in from the sound device and from madi with no change. I also tried changing the clock source on the ilive and didn’t change. I tried another sounddevice and a different mixer. The card works perfectly as I have the different mixer plugged into it. I did try to unplug the mixer to see if that was an issue.
Anyone have any specs on the madi card or ideas why it wouldn’t be working
@ddff_lv that’s what I am thinking. I haven’t tried it with another ilive but it could be the recorder. I have a secondary monitor console connected and works perfectly. I tried even plugging the recorder into that console by itself and didn’t get anything. I think you are right it’s the recorder.
@RayS no it has streamlock but the healthy link has a red x
Then there is an error count of a high number. I have checked all of the settings of the console and the sync settings of madi recorder and it won’t sync correctly no matter the combination of where I pull the sync from
