Right now, I believe you are limited to only 2 iPads on the Qu systems using QU-Pad. All of the other boards I’ve used do not have such a limit. I like to use 3 iPads when I’m mixing remotely by iPad only.
Please increase this limit.
Thanks.
Thanks.
2 iPads running QuPad and others running QuYou up to a total of 8.
What makes you think there’s unlimited resources available?
There should certainly be more resources than can run just 2 iPads. Particularly for a QU-Pac.
I’m sure if it were possible, it would have been provided when the multiclient feature was first released. It was probably limited to two for a good reason.
