Document says in text
Qu-16 is 24out/22in, Qu-24 is 32out/30in, and Qu-32, Qu-Pac and Qu-SB are 32out/32in.
But the block diagram on page8 has 30 out on my copy with 32 in depending how you view in/out.
Possibly a typo. Or misleading by combining two models 24 & 32 in the same manual.
If 24 & 32 have different numbers they need separate block diagrams.
Did the manual state that or do we have to use ESP to realize that is what they did?
Am I supposed to know that the lack of parenthesis means that was the Qu24 number on the block diagram?
If the Qu32 number is different why is it not also shown there with the parenthesis around it?
Sorry but this is a manual error. Not the worst but if that data was critical like in a recent thread then it is bad.
I’m not sure I see the problem with the way it is presented currently.
Are you suggesting that someone has skipped past all marketing documentation, specifications and copy, then looked at a block digram labelled Qu-24/Qu-32, and thought the larger channel count numbers (in parentheses) were referring to the smaller channel count mixer?
Also, are you referring to USB channel count here? (you didn’t mention).
Please also let me know the thread you refer to with the critical data.
to make it clear for everybody else reading this…
he (volounteer) refers to the USB interface
and nothing else, but he don’t need to tell us
Qu-24 has 24 mono strips 3 stereo strips all in all 30 USB inputs
Qu-32 has 32 mono inputs so all available 32 streams can be used with the desk
same for QU-SB and QU-PAC since they share the QU-32 engine
Which has nothing to do with the block diagram and the number of usbs in/out and where.
@KeithJ A&H
Yes. I always go to the block diagram first. I did that in reponse to questions in another thread.
I read it as the Qu32 had the number of usbs indicated ; although apparently that number only applied to the Qu24.
There should have been parens with the Qu32 number too , if it is actually different.
If only there were an easy way to search for threads or even responses. I am pretty sure it was in the last week or so.
the numbers you are referring indicate that you are talking about the USB
otherwise the numbers used are simply wrong
at least the marked text in my picture shows that it is USB related
why not make a picture and mark the problems in the drawing if there any
this would sort all confusion easily
If a user knows the right number to add they could do that but why should they have to?
AH should have indicated all different numbers with the () if they are going to combine different products in one manual and use that code for the models on one diagram.
And they should have shown all models discussed with pictures when they differed by what was being described.
@KeithJ A&H
I never noticed the search box on the right.
