USB Audio Playback on DM0
Hi A&H
There are 4 venues, each equipped with installed QU-SB where the USB playback is heavily utilized. Has been working like a charm for 6 years.
Each venue we will be upgraded to DM0 with several DT164-W and the control remain surfaceless with an iPad. With great disappointment it has been noticed, while it is an upgrade to the flagship system for a truckload of money, from the playback standpoint it will be a downgrade because in a surfaceless operation dLive is not supporting playback. I don’t want to connect any third party equipment to the system like computer, bluetooth receiver etc…
Would you please provide a solution to either play audio from DM0’s internal storage (similar to AHM) or release an interface card with USB or SD card slot (similar to other vendors)?
Thank you!
+1
I feel that it is a necessity for the DM0 to import and playback audio via USB-A.
I would also like to see an I/O option card that has a USB-A as well as a USB-B port with multi-track USB-Audio interface capability.
