Because the USB audio isn’t in the snake, but a local port on the machine, the ME-1’s don’t seem to be able to access it.
I have an Apple Airport plugged into the snake currently, which they can use… so… is there anyway I can force the USB audio out the same channel as the Aiport??
You can patch a number of things to connected ME-1s, including surface inputs, by using the Monitor tab in the I/O screen. To route the USB audio to ME-1 for example, select the required Monitor output, then choose USB Play from the drop-down menu.
