USB B Streaming + Routing
Im trying to Set up a Qu-32 i bought yesterday, i have followed the set up using the user guide and the DAW control set up notes provided. the problem im having is the signal im getting back through the monitors is mono, i believe the issue im having is that when i change the channels in the pre amp source to USB ST1 ST2 and ST3 dont change and simply have an X. can anyone help?
thanks
Firmware version?
Does the QU32 support USB input to all 38 channels,
From page 63 of the current (1.6) manual it looks like it only supports 32 channels in, so that will be Ch1-32. Those will then need to be panned to provide stereo imaging.
Hi 591,
Bob is correct, the USB B inputs on Qu32 are on a fixed map to CH1-32. I would suggest sending the stereo channels to an odd/even pair, and link the mono input channels they feed.
