I’d like to ask which USB stick or drives are compatible with CQ12 or CQ series?
Is there any list which is approved by A&H?
I tried some cheapo USB 2.0 stick but after formatting it with the CQ12 it was not ever readable with a laptop.
That’s to do with the File system in use at the computer. If you format the stick on the CQ it creates the file system on the CQ as Fat32.
If your computer operating system can’t read FAT32 drives you would need additional software which can,
It could also be the cheap stick itself but I’d suspect the file system first so check that with your disk info feature on your computer.
Hope this helps
David
