USB Key for ME-1
I have been trying to install a set ME-1s and I wanted to upgrade them to the latest firmware, but I cannot get any of my units to recognize any USB fob.
Are there any tricks to this? Size limitations? I have tried new ones (4G - FAT32) and reformatted older ones (1G FAT16).
Mark Pease
Tech Directory
Foothills Baptist Church
Phoenix, AZ
As above, I am trying to update mine, but the units say no usb key found…Im using the same key that I use to update our QU16.
Hi Guys
Sorry to hear you’re having problems updating. The ME-1 should support FAT32 USB keys; one suggestion is to format the key, then make sure that there is nothing else on the USB key other than the firmware.
The Qu16 USB key support is derived from the ME-1, but the improvements made as part of the Qu project have not been ported back into ME-1 yet. We hope to do this as part of a future firmware release.
Hope this helps
  • Jeff, A&H
Oddly enough I have 2 keys I have been using. Both are FAT32. One will work fine on any GLD desk I have tried, but won’t work on the GLD editor or an ME-1(freezes up the ME-1). The other key works fine on all 3. I have not gotten a QU in yet(backordered) so will be interested to see how it works. Can’t figure out why. The one that is erratic is a small(250MB) drive. The one that works fine on all is a 16GB. I have done 1.30 updates to 2 desks with it and it has a bunch of unrelated files and all my show files etc. along with the firmware.
I got it to work!
I got a new Sandisk 16G. Plugged it in to a ME-1 and it was not recognized. Grr…
I plugged it into may computer (a Mac) the drive had some software preinstalled. Opend Disk Utilities and erased the drive. I also renamed from “NO NAME” to “NONAM”.
This time, when I plugged it into the ME-1, it was recognized! I saved the configuration, installed the upgrade, and it worked.
Now I am ready for the ME-U when it comes.
Mark.
I too am completely unable to format any of my USB sticks to work. I have one old stick which is half broken and about to snap off which does work - it was already formatted to FAT32 and has loads of other stuff on it but I was able to flash the new update with it. However it’s about to die.
I have another stick which appears to be recognised but trying to save onto it hangs the ME-1.
Trying to format anything else to any format, any allocation unit value etc. does not work for me. I even ensured it was just called ‘ME’ and still nothing is recognised.
Is there a list of specific formats which should work?
Many thanks, Alan.
I also tried a low level format as well as intialising.
Hi Alan
Sorry that you’re having trouble finding a USB key that works with ME-1. The only supported format for the USB key is FAT32.
One thing you could try is to make sure there is only one partition on the key. Many drives come with hidden partitions, and these are not touched by a simple ‘format’. There should be plenty of information online for how to get rid of any hidden partitions on a USB key. ‘Diskpart’ seems to be the windows console command to use, but I don’t have any experience of using this myself.
Hope this helps
  • Jeff, A&H
Hi Jeff, I’ve just tried that and no joy.
Does the USB key have to be below a certain size? The one stick which does work for me is old and only 512MB capacity. All my others are like 16GB and up.
Thanks for any info, Alan.
Hi Alan
ME-1 supports FAT32 only, and the maximum volume size for this filesystem is 32 gigabytes.
I don’t have a definitive solution for you, but if it was me, I would just try a couple of cheap, small drives, freshly formatted as FAT32.
I don’t know when the next ME-1 firmware is planned for, but improved USB key support is probably the biggest outstanding issue at this point. Not that this helps you now, but we are aware that this needs improvement.
Cheers
  • Jeff, A&H
Hi Jeff, I’ve just noticed a release of V1.11 - is the USB key issue still down for a future update?
Thanks, Alan.
I recently setup 6 units. I went through about 4-5 FAT 32 formatted keys before I found one that worked.
Hi Alan
I wasn’t involved in the latest firmware, but my understanding is that it focused on the most common tech support issues. It doesn’t look like USB key support made that list, sorry.
  • Jeff, A&H
Okay, thanks for the quick info.
I’m trying to update form 1.11 to the current release 1.13
I’m using the usb key that I used last time to update me-1, also today to update qu16.
I did a fat32 format, then copied on the new firmware (M0.pad and M4.pad)
The ME-1 firmware update page says On USB: Not found.
But when I read the USB key in my pc, ME-1 has created ME1CFG and ME1PST folders, and the presets have been saved in ME1PST - PRESET.ME1
So why can’t I update ME1?
Oops, I was being silly.
I copied the files to the root of the drive, should have been the ME1 folder!
Until now i still figure out why i cant update my ME-1 using flashdisk. i try to change 3 flashdisk already. format and no file inside anymore, still cant update, weird part ME-1 detected my flashdisk when i try to save my preset
I’va had one USB that worked, so I thought all should work. Now I bought 10 new ones for my band, and none works - trying to export user-settings results in a freeze on all of our six ME-1’s with any of the 10 USB-sticks.
The problem is not solved!
I too made the mistake of copying the files onto the root directory rather than copying the entire ME1 folder when updating the Me-1.
I got mine working, but it didn’t make sense why this would need to be done.
  1. Format your drive FAT32.
  2. Download the latest firmware for the ME1, extract it, and place the ME1 folder in the root of the USB drive.
  3. Stick it in your ME-1 and go.
Without the ME1 folder, the monitor stations kept locking up even though they recognized the USB drive existed.
