USB Looping
Feature suggestion to apply a load buffer to USB playback so that if you had a drum loop for example, you would be able to effectively loop it with no gap in audio as the track is reset to the beginning.
You could then scroll through loops by applying a softkey set to stereo play and next.
This could be very effective for multiple performance use cases.
