USB MIDI with Qlab
Hopefully this is as straight forwards as I think it is but don’t actually have the console infront of me at the moment to check.
Is it possible to assign a midi note to a soft key to trigger specific cues in a cue cart in qlab? Is it also possible to assign a soft key to send a note to be a ‘GO’ button for qlab?
@Kieran
Yes, you can assign Custom MIDI messages to any SoftKey and these can be note on/off’s if you wish.
You can even have different ones for press and release, say for example with your GO message, it could be actioned on release just in case someone gets excited and presses it a little early…
(As you don’t have the console to hand, you can see this in Director - https://www.allen-heath.com/dlive-home/dlive-director/ )
Cheers,
EDIT: There is no direct USB MIDI compatibility though, the messaging would be via the dLive network port.
