It’s a real shame that the Avantis doesn’t support USB multitracking like the SQ / QU desks do. I own both and it’s a feature I use all the time, and is the primary reason I’m relucant to upgrade. I know I can buy a Waves card but it’s a lot extra for a feature that is already built in ‘lower’ specification desks.
Is this a hardware limitation or is it something that could potentially be opened up in future firmware releases?
Seconded a second time. We installed our Avantis at the same time as an SQ6 and I was shocked (and disappointed) to learn that we could only do 2 channel USB on the Avantis. Definitely need multi-track USB!
I want to indirectly third this but add that I do realize that basically no pro-level console (Avantis and above, DiGiCo or Yamaha QL/CL and above) offers native USB. I do like that DiGiCo at least offers a UB-MADI card for the S21/S31 and think that something similar might be useful here. Of course in most scenarios it’ll be Dante or Waves SoundGrid, but at least having the option for a 48 channel UB-MADI (or equivalent card using the SQ USB processing) can be useful in situations where a user might not want to set up a full network to support Dante/WSG.
Coming from the S21 I agree that it’s disappointing that Avantis doesn’t offer it over USB.
We just had a demo of the Avantis yesterday and I asked them about it. (Distributor, not A&H directly).
They suggested that it’s probably impossible to add as a firmware update as it would likely require extra hardware, driving the price of the product up. Same goes for allowing multitrack playback from the internal harddrive. I’m not sure if it’s true, of course, but it seems plausible. So don’t get your hopes up.
It’s likely that we’ll just be dependent on Dante for multitracking.
UB-MADI is definitely easier to set up, but it has its limitations. It perhaps couldn’t handle 64 channels at 96k…
That said, the Avantis offers so many advantages over the S21 that although disappointed about this omission, we’ll definitely let it slide as we’d be getting a Dante card anyway.
(whoops … didn’t realize I had already replied to this topic before @mods can remove this if desired.)
I’ll add my “me too” to this thread. An add-on card is fine to ad UB-MADI like, or if desired, they could swing a bit higher and go with Thunderbolt/USB3 to get the full 64@24/96. I do expect this to be a lower priority item, but it could be useful in some situations.
This feature is so huge in the SQ/Qu Range. Really sad it’s not implemented, like they did with the SLink Port, which is brilliant.
At least a Recording of 4 or 6 Channel directly to USB or local would help. When Im Doing a Quick „live recording“ as FOH I just Need Main LR + Ambience Mics. To buy a Dante card + Mac Just for Recording that is annoying.
New Avantis user here. Very happy with the console and features, sonics, etc… but really really missing the USB Multitrack function.
Please consider adding this in next firmware update, much needed addition.
Many thanks in advance!
Cheers
+1
Hello !
I’m thinking of upgrading my SQ6 to Avantis Solo but I use multitrack recording a lot (often usb b, sometimes sq drive for small setups…) I also have an SQ waves card but buy the Avantis card to only record multitrack (for my use, with the D-pack I wouldn’t need to use a Waves system anymore…). The function/cost ratio increases significantly.
Is there a hardware limitation?
If not, can we hope that one day the function will be added by an evolution of the firmware?
Can we had an adapatator for SQ Waves card like M-DL-ADAPT ?
It’s been 3.5 years and still nothing on that topic. SQDrive is one of the reasons that keeps us from upgrading from SQ to Avantis (or even DLive).
Our mixers have to handle mostly everything from IEMs through rock’n’roll FOH and conferences / streams. In many cases, a multitrack recorder comes in really handy and is one of the reasons we still keep an SQ5…
However,
since Avantis has a USB-A connector, it may not be a USB-Audio interface for PCs, but rather an SSD that is connected directly like the SQ-Drive.
Avantis has a USB3 compatible connector, and I feel that 64Track Rec can evolve given the bandwidth.
Personally, I think it would be interesting to see the release of a 64IN64OUT audio interface product with SLink to USB3(B).
If this were to happen, it would serve as a backup for USB-REC on SQ, and would add functionality to Avantis.
I second that.
With that 20GB internal drive built in, it’s a shame they haven’t upgraded or created an affordable way to have multitrack recording at 96k and also have the option of having Autotune like in the recent models A&H is producing.
I guess that an option that can be installed on any of the ports in the back could include that and more and still be cheaper than getting Waves Superrack and Dante.
On a similar vein, there’s also no way to get multitrack to a computer without 3rd party hardware (Dante or Waves). That blows my mind. While getting this ability from a USB B or C connector is unlikely to happen, a box like the new MIDAS Cobalt, but with 1 or 2 Slink ports would be incredible. I’d rather pay $750-$1000 for that then $2,000+ for a Dante card.
Here I am taking part in thread-hijacking again, but this surprised me as well. With my last mixer I was able to plug in a USB cable, and with their proprietary driver I had complete access to every channel on that mixer. When I received the Avantis, I assumed the same functionality would exist. I plugged in the USB cable, and nothing. Checked the A&H website, and couldn’t find anything about a USB driver. Turns out if I want to record or use the virtual soundcheck option, I would have to use Dante and purchase a Dante VSC for the laptop. I was not impressed.
For the OP (and anyone else with both Avantis and SQ), you can still record and VSC (32 chans) via your SQ. Presumably you’re using GigaAce card or similar in the Avantis to split to the SQ. It’s clunky, but adapt and overcome…
Yep, looking to jump into A&H and the Avantis would have been a great place to start for our particular needs (especially with the 128x128 Dante option), but the lack of USB Multitrack is a definite deal-breaker here. We do not want to have to use Dante for low channel count tracking projects in a studio environment (<32ch), when we can just plug in a laptop with a lower series board (which will be a more common use case). Not really interested in the SQ+, so we are reluctantly dropping down the product range to pull the trigger on the QU-6D (LOL), thus sacking off the idea of using Dante for tracking with this board.
The new QU series is definitely a reluctant second choice due to its max I/O and routing, but we can make it work as a “starter board,” while we wait to see what potentially comes with the next generation of Avantis. Interestingly, if the new QU series could take Dante option cards (up to 64x64 but at least 32x32), and had colored channel strips like the SQ, it would have been a winner! Feature-hampered product segmentation sucks. Would have been all in here investment wise with the Avantis, but instead am on the fringes with QU.
I use my Dante I/O card currently for VSC but am also in the camp of wishing multi-track to SD or USB was available on the Avantis. If it’s a hardware limitation, I would be willing to use one of the I/O card slots to install a specific card just for this purpose. I’m exploring the ideas of an SQ with Dante or SQ with a GigaAce card in the Avantis just to use it as a fallback multi-track solution in addition to my laptop but it’s an expensive solution to this problem.
I’m not too concerned about the Avantis recording multitrack directly to a USB device, since that may well be a hardware limitation. However, recording multitrack directly to the local drive would be a fantastic feature. Being able to export the multitrack session to a USB stick afterwards would provide the best of both worlds. Even 16 to 32 channels of recording would be more than enough and would make this a very compelling addition.
Too much to hope for? Maybe. But then again, A&H already blew my mind with the 2.x upgrade, so I wouldn’t rule anything out. Fantastic update!
