Still having trouble with stability in the USB-B recording, although maybe I missed something in the procedure. Had 16 tracks routed via USB-B, SSD drive formatted and running visible in the utility window, meters for channels active, hit record in the multitrack window, use countdown rolling, everything appears normal with recording rolling, checked it every once in a while and all looked good. Finished gig, stopped the recording, based on the use counter looked like it used about 2 hours of time, pulled the drive and…nothing recorded. When plugged into the SQ I can see the directory MT002, but no track files. When I connect to Macbook I can see the SQ MT-002 directory and file header of 512b for each of the 16 tracks, rather than the expected ~2 gig file per track. So appears no audio, no recording, even though at the end of the gig the recording indicator showed it had been recording for about two hours. So now have to apologize to the band and set up another session if possible.
Not saying this isn’t operator error, but followed the same procedure a few weeks and ago and everything worked perfect. Appreciate if anyone else has had a similar experience and figured out something they were doing wrong or any thoughts about what I missed in the procedure.
I’ve noticed a few things have bit me recording to the SQ drive.
Routing - I had set it up for direct out from channel to the USB. I think this is set based that you had meters going.
Start the recording - Not a fan of the arm/play feature. You can arm the recording, but if you don’t play, nothing will record. Yes, I’ve armed it, saw the meters and had nothing.
I’ve noticed that for the sq drive is to check the yellow light. If you should be recording a and don’t have a light blinking, you are not recording. As for the USB-B in back, our initial setup was just patching the IO, haven’t dug too much into it yet.
I too am not happy about this stability. I sincerely hope that much attention has been paid to increasing its reliability in the upcoming software release. It’s really not good enough especially when what one is recording is a single, never-to-be-repeated concert. It is not really possible to apologise as JTRJAMMER was able to do.
Correction, I meant SQ-Drive vice USB-B on the back of the console. I was recording via SQ-Drive. Yes all the channels in the display window were listed correctly and chosen correctly
in the I/O routing. The yellow light next to USB input was blinking/flashing the entire time once I started recording. Only way I know to confirm it’s recording is when you see the countdown
and the yellow light blinking. Level readings were also active. Beyond that I don’t know what else to check. Remains a mystery why there is no audio, just file headers. Regarding apology to the band, that will go along with returning the fee for the recording. They were doing a multi-camera video shoot and wanted the multi-track audio for post-production. Not sure I will ever work for them again, although I am going to offer to mix and re-record anytime/place of their choosing. At this point I’m not sure what I would do different, so that may not be something to even offer. As you said I hope the pending firmware update brings some stability to this process or maybe try and run some tests to figure out if/what I missed in the procedure.
I’m confused… As far as I know, you cannot multitrack record via the USB-B socket? As in, SQ-drive is the USB port at the front of the console, not at the real. The rear port is only used for connecting to a computer, right?
There are 2 options to record.
SQ-Drive: With the USB socket on the upper right of the console by using an USB-Stick or a harddisk drive (SSD works best due to speed). But limited to 16 channels.
USB-B: USB-B connection on the rear of the SQ for a connection to a computer. Record of 32 inputs is possible. So you can connect to a DAW or any software that allows multi channel recording like “Tracks Live”.
Both connections can be used for playback as well.
I thought the Dante card only allows 32 channels when running @96k? If you want to record 64 channels over Dante, you need to SRC down to 48kHz, right?
And regarding the harddisk, isn’t SSD a bit overkill? After all, the databus is only USB 2.0 and not 3.0 - surely a fast 7200 rpm mechanical hard drive will be enough?
Friggin brilliant! Thanks for sending the link. Already rebuilt all of the files, now importing and exporting from Audacity. Somewhat time consuming, but hey, yesterday I had nothing, now
I have tracks. I think I pulled the drive too soon after the show ended…so question is how long does is take for the USB device to finalize headers and such after
you stop recording? Could be a challenge sometimes because most of the time they (you know them) want to pull power after the show.
The best way (visually) to see that the drive is safe to remove from the mixer is to wait until the yellow LED is off - this means the drive is not in use.
Alternatively, in the SQ-Drive screen you can see that the drive is safe to remove after pressing stop when the transport bar resets and the ‘Busy’ label disappears.
Wouldn’t dream of running a digital mixing system without a UPS, they are dirt cheap and buy a ton of security.
Hard drive wise my vote again is for the SSD Small ones are relatively cheap these days and you can always transfer the files to a mass storage drive back at the office. Another consideration is if the recordings are that important you need to be running a backup system as well, so Dante into a Gigabit switch feeding two machines, or better still take the redundant Dante stream to a second machine, though simple switches do seem pretty reliable, also feed power to your switch from the UPS as well.
Had thought about using an UPS, no longer thinking. Also agree with Ian that SSDs are the best option. Went through a couple of USB sticks with mixed results. Ended up using a Seagate 1 TB Backup Plus Slim, $50 from Fry’s Electronics. The Dante card for recording, recording backups and interfaces to other systems is very appealing.
