USB recording should have Level Signal pre main fader
Hi
As of now the recording is post main fader so when ever I change the volume in the h is use it would change the volume in the recording making it hard later for editing.
Please add a level signal for the recording so it should not rely on the main faders then recording could be set to pre-fader.
Thanks very much
For multitrack recording pre main fader should be default (with the option of post fader).
For stereo recording maybe post fader should be default. Or, at least, source selectable (mains, out1-2…5-6).
+1.
Most editors want their recording in same velocity,
Post faders means whenever the house is louder, recording will be louder, lowering the house for calming atmosphere makes the recording almost not hearable
Pre main L R fader recording to USB memory stick should be mandatory. I cannot imagine a use for the recording level to vary with the main outputs. Why isn’t these corrected?
