USB recording
Hello, this is my first post here, so please excuse me if this is the wrong forum. I am a newbie owner of a A&H ZEDi 10FX but I cannot seem to find a dedicated “ZED” series forum.
Also, I am a live performer, not a studio technician, so my recording knowledge is only adequate but limited.
I have a (recently bought) A&H ZEDi 10FX that I have connected to my iMac via USB for recording/playback, using Logic ProX.
I believe that the recording signal sent to logic (via USB) is taken directly from the input gains of the mixer, bypassing the onboard EQ and FX. This is fine, as I do all my signal processing within Logic
However, I have recently wanted to record clips directly to the computers “in built” camera (ibooth), but using the mixer as the audio source as the iMac mic is poor and I would like to add eq and fx directly to the audio signal.
I simply cannot find a way of adding fx or eq to the usb record signal. I have succeeded in adding EQ and FX using an auxiliary mix, and feeding the computer through the analogue “line in” route, but would prefer usb digital if possible.
I notice on the mixer Block Diagram, the USB record source is shown as “Default-Pre EQ”. Is there any internal switching to change this to POST eq/fx or any other way of adding the onboard eq and fx to the usb record output. (As a new user, perhaps I am missing some simple onboard routing switching).
This may be in common with all USB mixers, as I said, I am new to this but I hope I have explained my question clearly.
Thank you for reading…any help GREATLY appreciated…Brian
Hi! I also have the same question about EQ and FX. I’m using a QU-24 and I’m recording thru qu-drive and I want to give EQ and FX to the recording output. If you have figured out how, I would really appreciate if you share it here. Thanks!
I am hoping to eventally contact Allen & Heath directly. They appear to be (understanderbly) currently uncontactable but hopefully someone on this forum may have the answer before then. ?
what you mean with FX?
@machlopez
he is talking about a completly different device
everything you have to know is already covered many times in the QU forums
@Steffen R, I searched the forum before I replied in this thread but I did not found any topic that helped me. I only have limited knowledge in mixing.
My problem is: I’m using a QU-24. I’m recording using the qu-drive which I assigned in Mix 9&10. In the LR main speakers, FX, i.e.reverb, would come out but I do not hear any of it coming out in Mix 9&10. So, there is no reverb in the recorded audio. Can I put fx in the recording or is it just limited in the LR main?
Thanks.
@machlopez
that is still covered in many threads
the fx returns are inputs like all other inputs
Hi, I fear I may have made my original query more complicated than it needed to be…sorry.
(I think) put simply what need to know is…on the A&H ZEDi 10FX is it possible to add any of the ONBOARD mixer EQ or FX to the usb record signal POST EQ, rather than the (PRE-SET) PRE-EQ
FX and EQ are two different things…
the EQ is an inline processing
FX is send processing
set the recording source to 1, 2, L/R then you can put FX on the master and still have the first two channels without everything
there is no other way to do it with this mixer
thank you ??
So, I’ve solved the issue!
Sold the A&H Zedi-10fx and bought a Soundcraft!
@omb
good!
now tell us the solution for all who read this thread later who have the problem
I doubt that this will solve the issue…
It is by switch selectable if you want to sent dry channels or the main mix to the usb.
But if you a more stable with a soundcraft.
Richard
But if you a more stable with a Soundcraft.
Steffan, I appreciate your input, I really do, but…
After wasting much time trying to figure out what I wanted to do, which was in fact, quite a simple routing option that the A&H should have had the option to do, but in fact did not, (or was so confusing, I couldn’t figure it); I was up and running, working exactly as I wanted, within a couple of hours of taking delivery of the Soundcraft.
The A&H ZEDi-10fx is without doubt a quality mixing desk but maybe a little over complicated for a non-studio user like me and I would suggest, short of a few basic options that some users may desire, (as in my case).
Any way, I am sorted…issue solved, not out of pocket and happy!!
Many thanks all for your input but, FAR MORE IMPORTANT…KEEP SAFE AND MY VERY BEST WISHES AND LOVE TO YOU ALL IN THESE DANGEROUS TIMES !!
Wich Soundcraft?
Everyone,
Please keep the topics relevant to the Digital Community.
If you need assistance with analogue mixers, get in touch with our Support team at support.allen-heath.com or speak with your local A&H distributor. For user feedback, try one of several user forums online - Gearslutz and ProSoundWeb would be a good starting point.
Thread closed.
