Hi there
I use the CQ with a small vocal group and the lack of groups means I apply overall compression at the mix bus. During the shows and depending on the song I frequently need to monitor and tweak the compressor settings. Its a good few clicks to get from the Fader view to the Mix bus compressor processing page and then back to Fader view. If I could bring up this page via a soft key it would be so much quicker.
maybe I can hitch along with your request…
I think it would be great if we get more options to assign to the soft keys. I already asked for the different sends-to screens to be assignable to the softkeys. But your plan is better!! Just make all the pages soft key assignable!!
And a further suggestion… Could you please make it possible to use the keys under the screen tot toggle through the different tabs on that page.
So for the main fader: Coming from a different page, the first time you hit the fader button it goes to the main fader screen. If you press it again it goes unto the next fader page, etc…
The same for the other buttons. So Home button goed to Home first, then second press it goes to the next tab, etc..
You can maybe make it so that when you switch buttons it will start on the default ‘first’ position again. So you never ‘get lost’
(From fader screen, press home button, and you begin on the default home page (tab). If you go from effects to Fader, you begin with the main fader screen.)
This would make navigation through the different tabs MUCH faster!
