In my case, I have special Useraccount for musicians monitors on stage.
There is only access to the Aux mixes allowed.
If I now want to give them access to their Aux-Masters EQ and Compression, I have to allow them the access to the Mainouts EQ and Comp as well!?
Am I right or wrong here?
Okay, it seems i‘m the only one with this Problem :-/
Hi Alex,
It sounds like you may be giving a musician SQ-MixPad?
The app for musician monitor control is SQ4You, which only allows control of Auxes (not mains).
When a user is set to only have access to one mix, this is the only one they will be able to see in the SQ4You Assign Mix screen - so there is no possibility for them to control the Main LR processing.
This is also the reason you can block access from the MixPad app (just in case someone tried to log on with MixPad using their SQ4You login).
Hope this helps,
Ah, did not realize this on the SQ4You … thank you very much!
