User-level login for OneMix App – let musicians self-select their own AUX mix without Admin/FOH password
We run a church worship setup with a rotating team of musicians (different instruments/positions each week). Currently we have one shared Admin password used for both FOH mixing/system configuration and any Aux/monitor control — there’s no separate tier for musicians.
What we’d like is a simple 2-level login structure for the MixPad/Director app:
1) Admin – full console access: FOH mixing, system setup, network settings, user management (as it is today).
2) Musician / Aux-User – a restricted login that:
    • Does not require or expose the Admin password
    • Lets the musician choose which AUX mix they want to control, from a list of Aux mixes the Admin has pre-approved for that login (e.g. “Drums Monitor”, “Vocals Monitor”, “Keys Monitor”)
    • Restricts them to level/mute/EQ control only within their selected AUX — no access to FOH main mix, other users’ Aux mixes, routing, or system settings
There are several solutions available. Personal monitor apps or restricted access to the MixPad is possible.
But why not?
I would also have a look at dLive4You which, unlike OneMix, doesn’t require configuration of the iPad by an admin. Plus it can run on iPhones and Android too!
MixingStation does exactly that.
Thanks! Yes, we also use dlive4you, but I prefer the design and layout of the OneMix app for our application. That’s why I asked :slight_smile:
Thank you, I will check it out!
Thanks for your message!
If the musician wants to select the aux channel themselves in the OneMix app, they have to log in as the admin. Otherwise, it won’t work.
So admin access is currently the only solution to my problem. Or am I wrong?
