Hi All,
I am trying to set user rights, and I would like to block the main mix levels for some users.
I can block Auxes, Groups, Matrixes, but nothing to do with the front mix?
Eg. I would like to allow for a user to change aux mixes, but I don’t want to allow to change levels in the front mix.
Is it possible?
BR, Gábor
what is the reason for this?
monitors?
there is the SQ4You app to do this
@nwegab
I would have to check the manual to see the specifics.
The amount of user rights is rather coarse and not that flexible to tweaking.
Hi @SteffenR!
We use speakers for monitoring (not headphones). In this case, I don’t want to give monitor mixing to musicians (it can cause serious feedback problems).
Instead, I give monitor mixing to my colleague, who helps musicians on the stage.
MixPad seems to be better solution for this than SQ4You.
On the other hand, I don’t want to give a chance to others to change FOH mix.
I think, this is a good way to separate responsibilities.
BR, Gábor
