Using 2 IEM on one stereo aux for separate mix as mono
my church have a QU-32, I don’t have enough aux mix for my all singers , I am planning to purchase wireless IEM (PSM300 Dual Monitor System with 2x P3RA) is it possible to use the stereo aux for two separate mix ? how do you do the setup on the qu-32.
Have you considered the trick I used to use on old analogue desks?
Connect singer “A” to the left side of the aux, singer “B” to the right side.
Pan things only singer “A” wants hard left, things only singer “B” wants hard right, things they both want leave in the centre. Obviously you can use the pan control to vary the relative levels, so if “A” wants lots of the Sax, but singer “B” only wants a little bet then you pan the Sax to the left of centre.
The only downside is they will only get a mono mix.
Thanks for the response, I will certainly try your suggestion.
