When using an Audio Rack, such as the AB168, with the SQ, is it an either/or configuration?
That is … does the Audio Rack replace using all of the local mic inputs … or … can you use some from the Audio Rack and some from the local mic inputs on the back of the SQ? i.e. - 1-8 local and 9-16 from the Audio Rack. (similar to the blocks of 8 I/O on the X32 series)
Or … something like keep 1-16 local and use the Audio Rack for 17-24 ?
Hoping to see SQ documentation soon !
I don’t think anyone not from A&H will be able to confirm without seeing the documentation (unless it was mentioned in the Webinar, idk, I missed it,) but given that it’s a 48 channels console with potentially only 16x local preamps (SQ5,) and how the audio racks work with GLD\Qu, my guess is that it’ll be even more flexible than the X32 series: you’ll be able to use a mixture of local and remote preamps, AND there won’t be any “blocks-of-8” limitation like there is with the X32.
Yes you can mix and match local and remote I\O as you can with QU presently
Sweet … that is a most excellent feature !
it has an input and output patchbay
I do this all the time. Use local for wireless units or depending on stage wiring locations I may use existing copper lines to save customer money if they are already fitted in floor pockets. Then a stage box in a different location. Maybe run new copper lines from it to new wall or pocket locations or feed power amps or powered speakers. It’s completely selectabable in the source screen and I/O patch screens.
