Using FX channels improvements
Hi all,
During shows I always name my FX channels. I have two issues which could be improved I think :
  • Naming : I can’t believe anybody uses two different names for input and output. So why are they not linked together?
Now I have to type the same name twice… Not very important, but a little annoying and it would save time
  • Mix select. I would be great if you can use the MIX button on the FX return strip. Saves time and thinking.
regards,
Pascal
GLD80 :smiley:
+1 for both suggestions! my words!
GLD-80 / AR2412 / AR84 / Qu-16
The problem about assigning the FX ret Mix button as you propose is this:
This button is already defined as Mix out to Auxes, Groups, Mains, just like any other Input’s Mix button. Changing this would break the logic behind the whole forward/backward mix assign procedure and make things more confusing.
Other than that, I had the same thoughts before, too…
I like the mix button the way it is, if I want some reverb on the delay return I press “mix” on the return and push up a reverb send.
Chris
