Using ST1/ST2 inputs on Qu-32 mixer
I have a Qu-32 and have tried connecting different sound sources (keyboard, mixer) to ST1 and ST2 inputs, but I don’t hearany sound or see any indication in the meters. Do I need to activate ST1 or route it to the mains?
Has the patching been changed somehow ? You should at least see the input meters move I think ?
Do you hear something when you PAFL either stereo input ?
Giga
PS: you don’t have the stereo input configured so they pull from USB do you ?
I haven’t changed any of the settings. I have an audio signal going into channels 29 & 30 and I hear it, and I see the level meter LEDs light up, as expected. When I move the audio cables to either ST1 or ST2, I see nothing. Is there a configuration/routing screen in settings that I can fix this with?
ST1 & 2 inputs are on the top layer, first left side set of the channels.
Have you selected that layer?
What meters are you looking at?
That’s it, it works! Thank you very much!!!
Good to hear!
Look at setting the custom layer on the mixer. That is the layer you go to when hitting both the layer buttons at the same time. That may save you from so many layer changes buy putting the channels you need all in one layer.
