In both case, I tried the new feature mono/stereo state for channels and aux recalled in scene. I check every “safe” (Edit: and “global filter”), everything is allowed (and of course the 2 in “mixer config” Edit : in “global filter” section).
And here, too, you don’t mean “Safes”, but the “Recall Filters”?
And there, too, in all the scenes you switch between the “Mixer Configs” are not blocked.
[I found a solutions, but it’s weird]
Yeah, I mean “recall filters”, and then all scene I checked and “Mixer Configs” are not blocked. Sorry, don’t have the console under my eyes.
I test at home with SQ MixPad on PC and it works the way it should with a new show, but If I load the show from the console, and I have the same issue.
BUT, If I change a channel from mono to stereo, I store, and then back from stereo to mono and store, It works properly for the current scene, but not for the others. It’s like I have to update every scene by changing two times the state of a channel and store to works properly… Very weird
If you load a show from 1.5, both “Mixer Config” parameters in the “Global Filters” are likely blocked.
What happens if you do the following:
First, allow these two parameters and then save your start show as a new start show version 1.6.
And if you only start experimenting with the scenes afterward, do you still experience the strange behavior with the changes required two times?
So far, no one knows why they “forgot” it offline. (
However, you do not need “Recall filters” or “Cue List” for your test.
But you wrote that it still doesn’t work. (
