Avantis with 128x128 Dante IO card. Audio clock source is set to Internal 96 kHz.
Dell PC with following software installed
ASIO drivers
Dante Virtual Soundcard 64x64
Waves Tracks Live
Dante devices are configured for 48 kHz sampling rate.
The Avantis Virtual Soundcheck I/O setting has Dante channels 65-128 mapped the the 64 board channels. We have these connected to the Dell PC channels 1-64 in both directions.
Issue
The issue is that we only see the first 32 channels of audio in Tracks Live. I checked the Receive and Transmit windows for the devices in Dante Controller and see that the Avantis only appears to be sending the first 32 channels.
My first question should the Audio Clock Source setting in the Avantis be set to the IO Port where Dante card is installed to match the Dante clock or is there some other setting we are missing to get all 64 channels of audio to be sent?
As RS pointed out the Dante devices are configured with 48 kHz sampling rate in Dante Controller. Which is why I am wondering if there may be some other setting we are missing on the Avantis.
Does the card send out 64ch if you change the Virtual Soundcheck patch to 1-64?
Is ‘Record Send’ enabled in the Virtual Soundcheck screen? If not, the ‘normal’ patch to the I/O Port is used instead.
If you need further assistance with this, send us your show file and screenshots of your Dante Controller patch (both ways) in a ticket at support.allen-heath.com and we can look into it for you.
Thank you, Nicola. Our Avantis has other devices (BSS and wireless mic receivers) connected over lower Dante channels and I am hesitant to make changes to those just for testing this VSC issue. I think we can try starting from a lower channel patching to 33-96 and see if that makes any difference.
