Need help with control volume without gain into the mics
At least I can’t guess what you could mean.
Perhaps you should first formulate it in your native language and then use Google Translate for English.
If you translate it back into your language and still understand it, you can post the English version here.
There are two primary ways to control the volume of an input/channel: the source’s preamp gain (analog sources) or digital trim level (digital sources), and the actual fader of the channel the input is assigned to.
There are of course other places you can modify the gain structure of an individual input/channel (EQ, compression, FX, etc), and there are busses downstream where you can control gain as well (Main LR output for example).
Do anyone know how to
Connect the iPad or iPhone to the mixer do I have to have a separate router?
Try this link:
Unfortunately, we don’t know which mixer you have.
If it’s a CQ-12T, you will definitely need an external router for it.
