Waves V3 clock and sample rates
CDM64, C1500, Dante card w/adapter, Waves V3 card, SuperRack. Looking to run plugins and VSC via Soundgrid. SuperRack show the Waves card at 96. I can click to change to 48 but it simply doesn’t change. Is this because of the clock settings? I’m not on-site and can’t remember what the clock setting is for the Waves card.
Correct. Waves has to be master in order to run at 48kHz. You have to set the DLive clock to slave to the Waves Card port. You will also need to set the Dante card to slave as well.
