Where in the signal path is the ME-1 fed?
I’m just wondering at what point the signal is fed to the ME-1 personal mixing stations. Post EQ? Post compression? I just want to know what affects the performers onstage after I change something on the GLD.
It depends how you have your output patch set up, take a look at the “Monitor” tab in the I/O page. The default is for it to be the channel direct out. I can’t see the bottom half of the editor on this laptop but you can change the direct out pick off point.
Chris
I think he also wants to know where that direct out picks off. I don’t have a block diagram handy to see that. That is important.
That can be set in Processing>routing>direct out. Select which pick point you want. It is a global setting. Affects all channels.
Thanks! That’s exactly what I needed!
