Which talkback microphone to get?
Hey guys,
I have a Qu-32. I was wondering which talkback microphone people recommend. I got this Pyle microphone, but I’m not sure how the units “talk” functionality interacts with the Qu-32’s talk button. I noticed my Pyle also required 9V of power, and I wasn’t sure if the Qu would provide phantom power to it. Amazon.com: Desktop Gooseneck Wired Microphone System - Table Mounted Corded Voice Condenser Mic with Pop Filter - XLR to 1/4'' Sound Cord - for Karaoke, Conference, Studio Audio Recording - Pyle PDMIKC5 Black : Musical Instruments
Many thanks,
Nakul
It looks like that mic uses a 9 volt battery, so no phantom power needed. Not sure
if you need to hold the button on the mic to use it or not, some more pro desk top gooseneck mics let you configure the button function.
For the normal band sound sound check talkback mic use I find a headset mic works best, no need to keep leaning over to the mic.
In the Qu talkback mic set up menu you can set it up to be either momentary or latching.
Thank you for the tips! I ended up returning the Pyle and getting this one which had Phantom power: Amazon.com: Professional Gooseneck Microphone Trusner Condenser Conference Microphone : Musical Instruments
It seems to work right when I have momentary latch on AND the Talk button pressed on my device. I don’t know if there’s any consequence to doing it this way so I’ve been leaving the talk button off on the Qu when I don’t have inter-room communication going on.
Why not purchase an extra of mics that you currently use, or a mic that you might use elsewhere in the future? An extra 57 or 58 work great as talkback mics.
Ooh, that’s a really tempting idea, Scott. I’ve been returning a lot of stuff on Amazon as of late, I might go ahead and go through with your suggestion!
We just used an old mic we were no longer using. Got a gooseneck stand that clamps to the edge of the table behind the board.
Using the same mic that’s being used for vocals onstage has always seemed like a good idea for band gigs. At the theatre, that doesn’t apply because of the odd positions of the little mics we glue to their heads so I’ve had good luck attaching a wired lav to the gooseneck lamp coming out of the back of the QU with some mini cable ties. Nothing in the way on the table, nothing to have to pick up to talk. Tends to be a quieter overall environment at FOH (compared to a band gig’s noisy soundcheck) so the lav has worked great.
Anyone have a good Bluetooth based solution, for talkback and headset? I’d love a Bluetooth transceiver that would do both.
Not sure if you would have a latency issue with bluetooth.
With my Qu Pac I use a standard wireless headset mic, Audio Technica
Pro 8HEcw, nothing fancy headset that works great for hands free talkback.
