Hi
As the question states why can I turn off and on mix assign for aux’s. This is not a feature on analogue consoles. You can send no level but why also have the on off selection.
I understand why you would have this for groups.
Hi
Well, smaller desks might not have the on/off button for individual aux sends, but Midas Heritage had this option, and I found it quite useful. Not sure if that has so much use in digital world, but I try to keep my routing clear even I could just turn down some unwanted signals.
ddff
Turning down the unwanted signal seems the obvious thing to do. I guess you could turn off aux assigns for specific channels to avoid sending signal accidental to the wrong aux.
quote:Yep. Something particularly useful to help prevent sending effects returns back into effects sends.
Originally posted by PyrodaveTurning down the unwanted signal seems the obvious thing to do. I guess you could turn off aux assigns for specific channels to avoid sending signal accidental to the wrong aux.
This is actually a common feature on higher-end analog desks like the Midas Heritage line, Yamaha PM-series, and many others. One benefit is that it allows you to turn off that aux send without losing the level you had it at if you want it back.
