I know this has been talked about already, but I couldn’t find an answer.
Is there a reason as to why there is no HPF on the Mix 1-10 outputs?
I understand technically you could pull down frequencies on the GEQ, but for obvious EQ knowledge that isn’t desirable.
Is this a hardware issue, not enough CPU power, or just not as requested as I would assume?
It has been for sure requested. Maybe A&H didn’t have any free resources because of the “Qu-you” thing (the F-word comes always to my mind when I read “Qu-you”… strange name). Maybe the DSP can’t handle it. Nobody knows. Wait for the next firmware update and see if it’s there. If not, wait for the next one after that. If you really need it, you will have to buy another mixer. I’m stil hoping but it’s been almost a year now…
May I ask why you may want to use a HPF on a Mix? For me, it’s like having one on the LR mix; just doesn’t make sense to me.
Don’t you use any HPF on your monitor wedges? If your wedges are passive and your amps don’t have a built-in HPF you need one in the mixers auxes. If your FOH goes down to 35Hz but your (vocal) monitors will only do 80Hz and up you need separate HPF settings for FOH and for the auxes.
If you have only active speakers with built-in HPFs and limiters and other kind of protection you of course don’t need any further HPFs in the mixer.
That job belongs to a crossover. The only reasonable alternative I can give you is to cut the unwanted frequencies in the Mix GEQ.
No, protecting a cab from too low frequencies is the job of exactly… a HPF. Trying to use the GEQ as a HPF makes everything even worse due to phase effects of the filters. Is is NOT recommended to use a GEQ as HPF.
A crossover is a form of HPF. It`s not the job of the mixer to protect your equipment. Your equipment should be protected no matter what your audio source is. And notice that the HPF on the QU have a slope meaning that there is still some leaks under the cutoff point. This is a mixer. Not a speaker processor.
I do know that this is not a speaker processor. What’s exactly your point? Is the SiEx1 a speaker processor? It has HPF on it’s auxes.
A crossover is NOT a form of HPF. Is has at least one HPF and one LPF. But it’s used for something else.
Protecting a cab from too low frequencies is not the job of a crossover. It’s the job of a HPF by definition. It can’t be done with a GEQ as you stated.
Look at this measurement of the FCS960 (see pic attached). I’m sure that’s new to you. No protection at all at 10Hz, the GEQ even boosts that frequency when you pull down its three first filters (25, 31 and 40Hz).
And: every HPF has a slope…
I’m with BLKGHOST om this. Protection is something that should be either in the amp rack or in the speaker itself. All modern PA systems should have some form of processing.
Putting protection into the desk is much like putting in a power amp. Not really its job, but a convenience for the lower end user.
I know what a crossover is. It splits your signal into frequency bands and any decent one will let you choose the frequencies to do what you want. And have you ever heard of brick wall filters? No slope on that one. Good for them if they included HPF on all their Auxes. Still not the job of the mixer to protect the equipement. When I go to a venue with my mixer, I don’t ask for the specs of their cabs to make sure I don’t damage them. Protection should be at another level than the mixer. I also know that the alternative I gave you isn’t the best one. But since you seem to need one so bad, that’s the only one you have for now without getting new equipemnt.
Mervaka, I agree. But maybe you just want less bass rumble or bleed on lower freqs on stage. Then it would become the job of the mixer again.
Ghost, the alternative you gave is not just not the best one. It’s not an alternative at all. That’s something new to you for sure, else you woulnd’t have proposed such a thing.
And have you ever heard a brick wall filter? Do they sound musical to your ears? Maybe that’s the reason why you won’t find them in any mixer.
I never said they sounded good. I’m just saying that not all HPF have a slope and can be useful to do exactly what you want in the lower frequency range where you wouldn’t hear much of a difference while providing maximum protection.
Maybe you can use the GEQ to reduce low freqs rumbling or bleeding. It depends on how wide the filters are. The FCS960 has two different widths, one for such a purpose.
Ok, Ghost. Then let me clarify myself: All HPFs you’ll find in a mixer have a slope.
But I agree that’s not the mixer what should supply low freq protection to the speakers.
Look I’m not trying to be a smart ass or anything. My whole point was just that it’s not something that I’m expecting from a mixer. The Qu have plenty of processing power left and I’d prefer to see more useful features like multi-band compression, side chains or dynamic EQ. Sorry if you felt offended in anyway. I feel that things are getting out of hand.
What, like all these people asking for features like side chain before HPF for output protection
Seriously - they’re both useful, but there isn’t really a “one is better” and without some sort of official word on any of them, and or any method of collating/viewing the community levels of support for a given feature it’s rather hard to draw any conclusions about the requests being made…
Ghost, no offense taken and none intended. I understand your point of view, and I agree: protection is not the mixer’s job.
