Wifi Router alternative - Perfect sollution
I have have been looking to tidy up my Wifi router and it’s wires that connects to my QU-24.
And now I think I have found the perfect solution.
It’s the TP-LINK’s RE200 Dual Band Wall Plug Wi-Fi Range Extender.
Pros:
  • Simple to setup
  • Uses only 1 wire. The Network cable from QU-24 to RE200 and the RE200 has the plug built in
  • Dual band 5GHz
I still have NOT tested the range.
How to setup
  • Plug the Network cable to the QU-24 and the other end to the RE200
  • Plug the RE200 to a power socet
  • Connect the Ipad to the Wifi net work called TP-LINK_5GHz_XXXXX with with the default password ABCDEF
    That’s it…
You can change the SSD name and the password by following the instructions that comes with RE200
Some venues might be able to use powerline links as well…
Let us know how you get on please.
