quote:
Originally posted by skyaudio
Any advice would be greatly appreciated.
Mark W. Clifford
Below is a re-post of my WiFi configuration, which works great. One key point is that I connect my MacBook running iLive Editor via ethernet cable, not WiFi. My iPads, naturally, all connect via WiFi. This has worked very, very well for me for almost a year now. I run my system with the MacBook/iPad combination only, no surface. Just love it. Maybe something here will help.
Apple AirPort Extreme
Model: 802.11n (5th Generation)
Firmware version: 7.6.3
Security: WPA2 Personal
IP address (static): 192.168.1.1
Subnet mask: 255.255.255.0
Router address: 192.168.1.1
Network NOT hidden
Radio mode: 802.11a/n - 802.11b/g/n (Automatic)
2.4 GHz channel: Automatic (usually 6)
5 GHz channel: Automatic (usually 36)
Router mode: DHCP only
DHCP range: 192.168.1.4 to 192.168.1.200
No reservations
DHCP lease: 1 day
Connected to iDR32 via Cat5e cable
MixRack
iDR32 V1.90
IP address: 192.168.1.2
Gateway: 192.168.1.1
MacBook Pro
2.4 GHz Intel Core 2 Duo
4 GB memory
Mac OS X Lion 10.7.5
Manual IP address (not DHCP) for Ethernet connection only, WiFi turned off
Connected to MixRack via Cat5e cable
IP address: 192.168.1.3
Router: 192.168.1.3 (so that MacBook can still communicate with the MixRack if the router goes down)
iLive Editor
V1.9
iPads
1 iPad2 running iOs 6.1.3
2 iPad2s running 5.1.1
All are DHCP clients connecting to 5GHz network only
MixPad
All V1.91
