XLR Mic splitter into AR2412->QU ST3
I am planning to use ST3 on QU as a (dynamic) mic input via AR2412 and need to split that to feed LR of the stereo input, there being no option for L/Mono when using AR2412.
Will a simple parallel wired XLR splitter lead support this well enough or should I go for a transformer based splitter box?
I would think a simply Y cable would work here, provided you do not turn on phantom power on either input channel …
Why not just make LR mono anyway? On the D Snake patch you have the options of making any output channel LR Pre L, LR Pre R, LR L, LR R, L+R Pre or L+R. You could just pan all your channels to the L and patch your D Snake outputs LR L. Then everything will be mono.
Or you can use one of the mono mix outputs (Mix 1-4) to feed the P.A., making the P.A. mono. Assign all of your channels to one of those mix outputs. Then you wouldn’t have to concern yourself with panning or cables.
If feeding a St input from an AR2412, simply patch the one input to both sides in the desk routing. No need for any splitter cable.
Unless I’m missing something, the option to patch the one input to both sides of ST is not available on a QU (16), just pairs of adjacent odd/even inputs.
@airickess, thanks, yes the single side method is an option. I think I would prefer not to lose the stereo in this case, even though FOH sound is predominantly mono it’s good to have the option of stereo FX or a (narrow) stereo image.
@JohnK, thanks, I will give this a try, I will not be using phantom there!
“Unless I’m missing something, the option to patch the one input to both sides of ST is not available on a QU (16), just pairs of adjacent odd/even inputs.”
You’re right! I’ve remembered that wrong! Sorry.
No problem! :slight_smile:
I’ve now tested this with a Y-splitter cable and it works fine, a simple cheap solution to gain an extra mic channel!
