Hi, i have noticed when using the crossfader in smooth curve mode the volume dips when the fader is in the center. Is there a way to rectify this at all. I prefer to use the crossfader when mixing rather than the channel faders.
Thanks in advance.
Thanks in advance.
Hi @Benjamin
Not sure which option you refer to by ‘smooth curve’ (Constant power, Transition, or Fast-cut), but from your description I assume it’s Constant power; XFADER curve switch set right ><
If so, perhaps some misunderstanding?
In the centre position, using this option, the control fades the channel signal between fully on and fully off across the fader’s travel. So, centre position is intensionally midway between min and max level.
Try the Transition option (XFADER curve switch set centre), where the channel level remains constant (fully on) across more of the crossfader travel before dropping to fully off.
