Xone 24c odd behaviour
Hi everyone.
I am experiencing some odd behaviour on my Xone 24c mixer. I am using the mixer with Traktor pro 4 on my windows laptop and with Djay pro AI on my ipad (10. gen).
After approx. an hour of using the mixer in dvs mode the left channel LED starts to flash as if there was a signal present but there isn’t. The deck is stopped, the needle not on the timecode vinyl and still the indicator LED shows a signal present by flashing. I unplugged then all the cables except the power cord and still the left channel indicator LED is flashing as if there is a signal present.
Like i said i am using traktor and djay pro and it happens no matter which of both softwares i am using.
Could this be a malfunctioning soundcard or internal routing error or some other faulty part within the mixer and should i return the mixer to the dealer??
Thank in advance.
Hi @stsc82
I’ve sent a reply on your support ticket this morning.
Thanks for the video you sent us there.
Unfortunately this issue appears to be a hardware fault with the channel’s SIG LED circuitry so, yes, please reach out to your dealer to make arragements for the problem to be resolved under warranty.
Apologies for any inconvenience
Hi @Xoneofficial - I am getting the same problem with my Xone 24C. I’m using vinyl only (phono inputs) and recording via USB to a iPad. Without any records playing, the signal lights on both channels (and the aux/mic channel) are all flashing green. Seems to be a heat issue as turning the mixer off for a while sorts it. There is no audio noise, just the LEDs flickering. Is there any other solution or I should speak to the vendor I got it from? Thank
Hi @Errorcodes
If it’s the same symptoms, the issue requires a hardware fix, so for warranted support reach out to your supplier, or our official distribution partner in your region.
