Hello everyone,
I’m trying to record a set with the simplest setup from a Xone 96, and it came down to Record Out → ⅛ jack → Rode SC4 TRS to TRRS → ⅛ jack to Lighting → iPhone. I have as inputs 2 CDJ 3000s.
The issue is the signal is way too loud for the iPhone when the trim of those 2 line inputs is set to unity, meaning the recording is completely saturated and distorted when playing it back, basically useless.
I found out that when the trim is set to roughly 9 o’clock, the recording is OK, though probably not great, and I’ll have to readjust the level after recording. Is there something wrong with my mixer or is this normal? Ideally I was hoping that the mixer would send out a clean signal that can be used immediately without adjusting the gain.
Would this also be an issue with a better recorder, like a Tascam DR-05, or can that device handle the high output?
