i’m windows 11 user with traktor pro and i can buy a xone db2 second hand. I want to use the xone db2 together with Traktor as a USB-Soundcard to get the 4 decks digitaly on the mixer. I don’t want to use the mixer as midi-controller. Does someone run this setup succesfully?
Thx for your support and answers…
Greetings,
Danny
Yes I have db2 working with Traktor 4 Pro with 4 deck mixing
I dont use midi side some much but you can setup digital channels
Richard
Thx, i installed the driver and the db2 works with traktor and windows 11. However, it does happen that the audio playback cuts out completely and, after turning the DB2 off and on again, resumes exactly at the previous playback position. So, it does not run completely reliably, and I have not yet found a solution for this.
Same problem here. Unfortunately i can’t play on stage with that. What a pitty! But i guess there won’t come an update driver or something for db2 + win11 ?!
does this still occur? anybody know if win 10 would fix it?
