Xone K2 fader replacement
Hello everyone, I need help finding a replacement for the fader of the Xone K2. I found that the reference is AI4999 but I am not sure which one is the correct one. If someone could give me advice on how to find the correct one I would appreciate it alot
How do you mean the correct one?
That reference shows one fader replacement for me. Are you seeing different types?
thanks for replying, the ones that I found dont show the physical size of the replacement. I understand it has to be 7cm but I haven’t found anything that show those details so far. Could you show me the replacement you found to see them? thanks again for the quick response
None of the sites I found seem to give the fader dimensions, but all state that they are compatible with the K2.
Some examples:
Thanks a lot! Yes I found some similar but a I am little afraid of them being compatible, it should as it says there but still afraid since I am not sure what I am buying. Thanks again for your help!
If the site says it is compatible, then you can always return it for a full refund if it turns out it isn’t.
Pain in the butt, I know, but you still have that security there.
Usually what I do is take a screenshot of the listing on the site before buying, just in case there is a chance that it is wrong. That way they can’t just change it and claim I bought the wrong thing :rofl:
Yeah is a little frustrating, they don’t even have enough pictures to tell if its the right one you just have to trust them LOLOL
It’ll be fine. And at least they are cheap enough.
