I mapped faders for same function (volume) on two Layers that I currently use.
When I switch Layer I want immediate response from current position, but now in most cases (but not always) I must to move fader up/down few times to “pick up” fader on Layer… It’s very inconvenient…
“ALL CONTROLS - In this state, all controls on the surface are linked to Latching Layers. The faders and pots have an embedded soft pick up algorithm to provide seamless integration across layers.“
Even when I’m not switching layers, but working on a single layer, once the fader is in the up/down position, it often becomes impossible to move it immediately when mixing tracks.
I am having the exact same problem with my K3 - I am using Algoriddims DJay software on PC, and sometimes they work straight away, sometimes it can take 3 or 4 full movements of the sliders/knobs before they register, even when not switching layers, although switching layers seems to make the problem more prevailant.
I’ve seen the exact same behavior too, and it’s really annoying because it completely takes me out of the flow. I’m using the K3 with Ableton, and sometimes it just takes several movements before Ableton finally picks up the knob or fader.
