Zed 436
I want to Know if the Zed 436 works with any audio workstation (like cubase) or if only works with sonar, and if in may workstation i can acess to all parameters of the mixer, if i can record all channels individually to my workstation
Hi Grooveon
Yes you can connect a ZED 436 to Cubase or Sonar.
What do you mean by all parameters?
No you cannot record all channels individually and simultaneously to the workstation. If you wish to do this i suggest you look at the
ZEDR16 https://www.allen-heath.co.uk/zed/zedr16 or GSR24 https://www.allen-heath.co.uk/gsr24
Hope this helps.
Please note this is also the iLive forum.
Here you can find lots of forum support for the ZED series of mixers.
https://www.gearslutz.com/board/search.php?searchid=35147605
Regards
Sam
What i mean when i say “all parameters” is for example, if i want to record a band, if i can record all the mics individually while the band plays? (with the Zed 436)
“No you cannot record all channels individually and simultaneously to the workstation.”
Ok, Thanks a lot
