ZED i 10 USB output "track" routing
I think I know the answer… but is there a way to “repatch” the output tracks on the ZED i series.
Moving the main Left Right mix to tracks 1 & 2 would be handy and some software only see those.
I know if could be dome with some external jumpers, but looking for cleaner option
@Mike C
Not really - the different options for USB out are achieved with analogue/hardware switches, which affect USB outputs 3&4 on the ZEDi-10 and ZEDi-10FX.
On Windows, with the driver installed, there are two stereo devices (+ 4x mono) presented for use with any app, and via ASIO and a DAW you can generally route as you like.
On Mac some apps will see the first two channels as stereo and then the rest summed to mono.
There are work-arounds using software like Jack audio to repatch in this case, but it’s not really cleaner as it takes quite a bit of setting up.
If you want to explore this further, please contact us through support.allen-heath.com
Cheers,
Keith
Thanks for getting back with me. This would be for use with a Mac Book used for live streaming and the streaming software only sees the first two tracks/channels.
Now using a ZED 10 and it works perfect.
I get some time and see what “Jack Audio” is about.
