Howdy Fellas,
So I thought to write the conclusion to this saga and want to thank fellow audiophiles for ringing in here to help.
I was never successful in getting A&H to reach out directly to me but my pro audio rep was able to get them to respond and he forwarded me the directions and diagrams. The diagrams had highlighted areas, not unlike the ones Esskuh posted on this thread (thanks Esskuh). Like MarkF, the email said I should not attempt this work myself. I called some shops and none could do the work before our next event so I proceeded with the modifications.
FYI, this mixer is beautiful inside, with each channel on an individual circuit board, which means it was hand assembled (creds to A&H).
The directions I received were straight up incorrect and so the first attempt landed me with a channel with the Aux Send permanently muted. I do not know if this is due to A&H or my Audio Rep interpreting. Of course I only modified one channel and then checked it for results, so at this point I decided to follow the circuits on the board to determine what made sense. As it turns out, the mod is only a 2 step process whereas the instructions I was sent outlined 3.
If anyone reading this wants to change the Mute Switches on their Zed 60 to Global, Here is how it is achieved:
Step One: Locate the JS1 connection and sever it by removing the R23 Resistor. This resistor is not really being used as a resistor, it is 0 impedance and so is really just a wire being used as a jumper. So remove it to sever the connection.
Step Two: Solder across the JS2 connection.
Your done! That’s it. Very simple if you know how to solder circuit boards. I learned soldering by building Radio Shack transistor radios back in the 70’s when I was like 10.
Making this mod to 8 channels took a quarter of the time it took to take the mixer apart and reassemble it. All total for this project was 2 hours start to finish, but without having to figure it out by following misleading directions first, I expect you could shave 20 minutes off that.
What is disappointing on the part of A&H is that they could have easily put jumpers at JS1 and JS2 and the user could then switch back and forth from local to global mute as desired by just moving the jumpers, no soldering necessary! Would be so easy and cost what, a few extra pennies? I do appreciate that MarkF, from A&H, chimed in on this thread, but unfortunately I never found an email from him.
At the end of it all, why A&H would chose the Mute Switches to not affect the Aux Sends by Default is a mystery. Every tech I have spoken with in the pro audio world has agreed with me that Global Mute by default would be preferred. I hope A&H fixes this for future units, it would be so easy. Had I not done this mod myself, I expect a shop would have charged around $450, which is more than half the cost of this mixer new.
In closing…
Analog sound rocks (but so does digital) just keep it live and keep it real.
