I’m having some trouble getting my Zedi-10fx to properly receive audio output from my DAW via USB. I’m using Ableton Live 11 on Mac 11.2.3 (m1).
On Live, I have the mixer selected as my audio input and output device with all input and outputs selected. The mixer will send audio to the DAW properly, but I can’t send audio from the DAW to the mixer’s main outs. Is there a step I missed? I don’t see clear guidance in the users manual.
By default, Ableton will probably be sending the main outs to ZEDi USB channels 1&2, which are routed through the ST2 channel when nothing is connected to it’s jack sockets. This channel is also shared by your FX return.
I’d recommend instead, setting Ableton to output on USB channels 3&4 as this will appear on the ZEDi’s dedicated USB return channel ST3.
You can then easily send ST3 to the main mix, or select it for the headphone/monitor mix and then use the XLRs=MONS switch to send this to the main XLR outputs.
