I’m stumped here and I’m hoping you guys can help. I’m convinced it’s a hardware issue at this point.
Windows 10, latest drivers for ZEDi 10FX and using Audacity as DAW.
I have a stereo signal (DJ Mixer - REC OUT) plugged into the L/R - ST1 1/4 jacks. The audio is coming in good though the headphones, definitely in stereo, meters show separation between the 2 channels…all good.
When I go to record via USB in Audacity I choose MME/ZEDi 10 3&4 and I get audio but it’s only the left channel being output into both channels of my “stereo” track. I have only the top button (M1-M2-L-R) pressed in the USB OUT section of the ZEDi.
Couple odd thing I noticed…
If I plug my headphones into the AUX OUT, I only get audio in the left channel of my headphones, is that normal? I tested the MONITORS OUT rca jacks & MAIN OUT xlrs, both are outputting in stereo as normal.
When I open the ZEDi USB Control Panel and check the “Buffer Settings” tab, it says “ASIO not active” under ASIO Status. Could this be my issue?
Thanks in advance!
