True but I would like to see a bigger picture of what he’s dealing and working with, system, speaker placement, the room, ect. Those factors all add up into the amount of available or lack of gain before feedback.
moderate size room ~~90x60x60 + stage and balcony
podium mike fixed position
one speaker - they are the problem
plenty of gain before feedback
upwards compressing will not lower GFB
The details are not relevant because they only change the possible gain value by some decibels. But any value of gain before feedback is the border you are not allow to pass. It is like the comparsion of a car with or without ABS. No matter wich car you use, there is one speed which will cause that you hit the wall. You cannot beat the physic. Hmm
unless they changed the laws of physics there is no more possibility of feedback problems when the loudest signal is lowered
same thing as lowering the faders to stop the problem
Unfortunately we know nothing about the rest of the system in question, make, models, how it’s been set up and aligned/rung out…if at all or even a general picture to get an idea of what he is working with.
I have asked many times.
Described above. Room is essentially flat. MD rung out problems with EQ on the mikes. Not my first choice but he runs things.
Use what you already have…….
Bring up the mic channel gain a fader level to the level needed for the soft speaking
people, give yourself a little room on the channel gain for the loud talkers.
For the loud talkers find the compressor threshold that clamps them down and yet does not touch the soft spoken people, try a 4 or 5 to 1 ratio and a longer release time so the comp does not pump.
If we do that then we do risk feedback howling. We have no control over the speakers or how loud they suddenly choose to yell.
Nor how soft they want to whisper. The ONLY answer is limiting the DR. We have compression on now but that does not help the low levels intelligibility. This is for an audience hearing spoken word and many of them are old with hearing problems. We need to control the DR and levels so they can understand the words.
It’s used more in the studio world that live, the SQ can do parallel out of the box.
The SQ may do it but some of the people here clearly do not use and and did not understand how UPwards compression works.
