Right, my serious list of featues.
Next generation iLive.
Must be backwards compatible with the current series in some form or other (maybe only use a new surface with an old rack, not an old rack with a new surface). I don’t want to lose the value of my hire stock overnight by not being able to use a new iLive with the old ones (not doing this might slow me down purchasing new ones).
Surface - dynamic LCD’s on the surface controls so that scales, labels and functions can change on the surface (ie the dynamics and EQ section), get rid of the screen printing.
Please don’t go to 96k, I’d sooner have more bit depth than a higher sample rate (giving more internal gain / headroom). Everyone with a real brain knows that 96k is just a stupid feature for marketing teams to plaster over everything.
more DSP horespower so things go as quick as the GLD
Faster boot up.
better surface metering / balistics, the current LED’s do not match the LCD screen ballistics. maybe even 3 old school analog VU meters on the surface or dedicated high res LCD VU meters that work in bright light, ditch the master LED VU meters, they are next to useless.
the ability to upgrade an iDR10 to iLive 2 would sell me for life on A&H’s awesomeness.
better gain sharing, (see point on higher bit depth) so that setting master gain almost becomes irrelevant.
lower noise floor.
automatic gain setting - press the autogain mode and all selected gains are set to give you an average signal level of 0dB based on the level of current inputs (ignore channels below a certain threshold).
user definable channel templates - select the channel then select Kick Drum Template and it:
Labels the channel
Routes it to a DCA called drums
Sets the gate -30dB
Sets up the compressor
select the “Acoustic Guitar” template and it:
Labels the channel
Routes it to a DCA called “Instruments”
Routes it to an instrument effect send
turns on the high pass to 200Hz
etc etc This would make setting up from scratch really quick, and would also be handy for schools / theaters where there may not be a lot of technical knowledge.
Accessories
- low cost Dante or ACE breakout boxes so you can have compact 8 in 4 out stage boxes and 16 in 8 out around the stage and get rid of all those analog multi’s.
Thats it for me.
Some of these things could probably be done on the current platform.
