Recall Safe Function for CQ Series
I’m currently using the CQ-18T in a live environment with multiple scenes per show, often switching between them during a set. While the CQ platform offers a good and streamlined workflow, I’ve identified a key feature that would greatly enhance usability during live performances and rehearsals. Feature Request: Recall Safe Function It would be helpful to have a Recall Safe function that allows certain channels or specific parameters (e.g. preamp gain, EQ, compressor, mute, FX sends) to be protected from being overwritten during scene recalls. This is especially important in workflows where adjustments to levels or processing are made during soundcheck or on-the-fly during a show — and must persist even as scenes are changed for different songs or cues. Suggested implementation: • Per-channel and/or per-parameter recall safe toggles • Simple visual indication on affected channels • Stored as part of the active Show (not Scene), so they remain consistent across a performance Many digital consoles (including your own SQ and dLive series) offer this functionality, and it would bring a big value to the CQ series without compromising its accessibility or simplicity. In addition, it would be useful to have an “All Safe” or “Global Apply” option that allows updated parameters — such as Gain, EQ, Dynamics, or FX Send levels — to be applied across all existing scenes in the current show.
What do you think about this request ?
Greetings from Vienna
+1 voted.
This would be very useful for loading scenes/shows without affecting performers IEM/monitor mixes.
I 100% support this request. +1 vote
Me too: I 100% support this request. +1 vote
“Buy a dLive if you want this feature, peasant!”
/s
In all seriousness, +1. This is immensely useful for cultural programs where you have diverse groups of performers.
+1 As a user of SQ, Avantis, AHM, and ILive, this is the one thing I miss on CQ. I know CQ is in a different league to the others mentioned, but this lack can be quite a problem when under pressure in live conditions.
Absolutely. I have experienced it during Soundcheck conditions.
I provided PA and FOH services for a two-day 60s weekend last October, an event I do annually for the same promoter. Given my familiarity with the venue and my background as a professional musician (which means I often know the acts performing), I usually have a head start on their technical needs.
This time, I opted to use the CQ-20B over my pre-configured QU-SB. The lack of “Safes” on the CQ-20B made switching between acts more stressful. However, the CQ-20B performed admirably, especially considering it’s not intended for such demanding use. My monitor engineer found the FBA limiting, wishing he could access both GEQ and PEQ simultaneously.
Despite these challenges, the CQ-20B truly impressed for a device geared towards less experienced users. I’d absolutely consider using it again for events with a smaller number of acts. Adding a “Safes” feature would be a huge improvement!
+1 for Safes to be added.
BTW – I’m seeing a lot of users type “+1” as a comment, but not as a proper Vote. Is this due to some structural limitation from the forum software?
I think there are a limited number of votes a person gets. When I hover over the “Vote” button it tells me I have a certain number remaining.
I think that’s tied to each user’s “trust” level on these boards. As you post more your trust level will get bumped up and I believe you’ll get more Votes.
Makes sense. I wouldn’t trust me either! :smiling_face_with_sunglasses:
+1 for this feature. I am new to this mixer and it is something I did not think about.
Oops! I didn’t realize I had an official vote…
I’d like to explain my interest in “safes” (and perhaps someone can give me some tips in the interim…) I’m using a CQ-12T as a drum set mixer for live performance. I carry my own sound reinforcement. Besides the basic mixing functions, I’m essentially using the mixer as a dual fx unit for signal processing the drums (gated reverb, longer snare reverb for ballads, flanging on hats, etc.) I have saved these fx settings in scenes. The problem is that when I get to the venue, mixing functions such a channel level, eq, master volume, etc., need to be modified, but routing and fx settings do not. I would like channel strip settings to be safe, as well as master volume, but have the fx chain be recalled per scene…
There is a more recent post requesting basically the same feature hopefully all the votes from both posts are combined and this feature is included in the next update.
This is an absolute must IMO. It would be nice to be able to choose which settings are replaced or safe from scene changes. I would primarily use scene changes for effects changes leaving all my levels and dynamics, eq, aux buss levels etc unchanged. I would also like to be able to turn off or mute each of the 2 effects units via the footswitch.
“Voted +1 — this feature would be really helpful for faster scene or show loading.”
Same issue. I run sound for our band on CQ20B whilst playing Keys too.
I have requested this feature before.
Problem is, tho I can see a use for scenes, namely, the only way of simple change of the FX rack items thru scene change BUT everything else changes (levels etc) when you dont want them too. To that, I can only use scenes as a recallable template at the beginning of a band session, pre soundcheck. After soundcheck, scene recall is pretty much a useless function in a small live band setup.
Meanwhile A&H works in slow motion making updates, mixing station already have safe on scenes.
