I’d like to have a soft key assign combo: Select FX and mix. What I’d like to do is press the soft key to feed channels to effect and immediately bring the effect to screen to edit f ex rev time.
iLiveT80 / iDr32
iLiveT80 / iDr32
Thought of another one while struggling with EQ for a problematic head-mic this morning:
Having an RTA that can be overlayed with the selected channel’s EQ curve would be wonderful.
“A computer once beat me at chess. It was no match for me at kickboxing.”
-unknown.
Thanks heaps for the latest update…really enjoying the added functions and changes…
Wondering if it is possible to add a quantizable, L&R linked/linkable, tap delay similar to those available in the TC D2 please…
Cheers and thank you
Dave S
Pua Audio Systems
Brisbane, Aust.
T112|iDR48
Hi! an UNDO function on scene manager, a multiband compressor, and a geq as an fx engine for insertion on imput channels
Solo se que no se nada
I’d like to be able to clear the contents of a scene without removeing the name of it. (clearing the check marks meaning no info in the scene) We use pretty much the same order and names of scenes each week, however the mix changes. I’d like to remove the contents prior to rehearsal and then save the scenes as we practice them without haing to place the names in them each week. This would allow one to know which scenes are fresh/currently updated scenes as opposed to ones that had been left over from the previous week.
Another option would be a notation in the scene window indicating when the selected was last updated or saved.
I don’t remember if anyone mentioned this: The parametre select could stay selected when changing fx. What I mean is that I adjust drum reverb decay and chance to voc/backline reverb I must select decay again.
iLiveT80 / iDr32
Can we perhaps have the option? Actually I could find it very useful, but I’d need to be able to it off so as not to confuse newcomers to the desk or to the differences between DCA/VCA’s and Groups - the point about confusion is valid.
-unknown.
A way to turn it on or off would be good. Because usually you use a DCA to group together things from pages that you don’t have open. So just to see the VU meters would tell you something about the signal. And something is usually better than nothing…
quote:
Originally posted by kjell@jll.noFor sure, routing VU meter on DCA is not possible in the “real” world. But as this is just “software” it would be great if it’s possible. At least when you have all faders for the DCA on page 3 it would be good to see what’s happening on that page.
Why not? I have worked on analogue desks where I was able to cue the VCA groups, technically cueing all member channels of that group and of course there was a level indication of all channels combined. That would equate a vca/dca group’s level meter.
Christian Tepfer
Hamburg, Germany
Key listen on the dynamics when using the Editor! Please
I would love to have VU-meter on DCA’s as well, if possible
quote:
Originally posted by josiaspiconeHi! an UNDO function on scene manager, a multiband compressor, and a geq as an fx engine for insertion on imput channels
i think that this functions could be very useful!!
Not sure how this could work! DCA’s are control groups not audio groups. There is no signal in them to meter!
A&H have an excellent paper on their site explaining the operation of DCA/VCA routing and operation.
Darren
I think this is first step to confusion between DCA and Group. I’d rather leave this as is.
ddff
quote:
Originally posted by lawbass61Any chance of making the GEQ’s on the outputs true 31 bands so we can get the very low (<63Hz) and very high(>16KHz), or at least extending the low end GEQ, this would be helpful in being able to tune the subwoofers. Thanks for the great product.
Jonathan Wade
Suburban Legend Audio
Agree. This was one of the first things I was missing when I first tested the system. Hope its possible to do something about this. I just think it is more comfortable to use the GEQ with faderflip, instead of having to tweek it via PEQ.
quote:
Originally posted by abstractnoiseCan we perhaps have the option? Actually I could find it very useful, but I’d need to be able to it off so as not to confuse newcomers to the desk or to the differences between DCA/VCA’s and Groups - the point about confusion is valid.
-unknown.
You could create some groups in your configuration (if you’re not maxed out) Assign the same channels to the groups as the DCA’s and don’t send the groups anywhere. Give them names, create your custom meters and use those as your reference. Just a thought!
Scott
More options on assigning gain/trim, send levels, direct out levels to the channel encoders. For instance I would like to put the gain/trim on the shift encoder with the send as the main function(when mix is active)or switch them around to any order I would like. Right now with gains/trims as the main function I have to use the shift to change send levels which is a pain when mixing. I just can’t seems to get the right combination I like here.
112T/IDR48/IDR16
@sraymond - yup, that’ll work, but burns output busses I’d really rather keep for Aux sends.
-unknown.
Yeah - I’d like to have meters working on the DCA’s(optional?). Just finished a theatre show with many vocal/orchestra DCA’s used and it would have been a godsend to have DCA meters during rehearsals for programming scenes as there was lots of offstage singing for example on surface layers that weren’t normally visable. As kjell said above: " something is usually better than nothing"
Cheers
Richard Howey
Audio Dynamite Ltd
IDR48/IDR16/T112/R72
