T112/T80 battery change & white screen reset SIMPLIFIED!
We’ve had an iLive system running at our church since `09 and it’s been a remarkably solid and reliable system, aside from the pesky battery issue. When I first had to change it, I went ahead and installed an extended battery holder to make future replacements much quicker and easier. But it always seems to be a battle trying to remember how to fix the white screen to get everything up and running again.
This time, I took some pics and documented the procedure (for ours with the AE7040 SBC) in hopes that it’ll help someone else who just needs a clear explanation of what to do. I realize this varies somewhat with the different SBCs that A&H used over the years, but the general steps are the same.
Here it is as a printable PDF. Hope this’ll help someone . . .
(White Oak Worship Center, Blairs VA)
iLive-T112-BATTERY-CHANGE-1.pdf (480 KB)
You my friend are a godsend! Thank you so much!
Very handy thank you, just remember though you must pic LCD+CRT or you will get no output from the external VGA port once the system has booted.
